STRIPES
\\\STRIPES/// going to the HD shop.
You are right. But, it isn't the "teeth" on the circumference of the gear that are slipping, it is the engagement dogs that slip into the gear slots on the adjoining gear that is on the common shaft. The upgrade gears have fewer engagement dogs but the dogs are bigger. The engagement slots are fewer but also larger to ensure a more positive hook up.
The corners on the stock gear dogs get rounded corners causing the gears to disengage when under more torque.
