Rocket Scientist
Grand Exulted Poobah
- Joined
- Sep 27, 2009
- Messages
- 6,851
- Location
- Spring Lake, Michigan
- Ride
- Black 05' Rocket III standard
Ive said this before, and I (and the engineering community) believe the failure mode we are seeing is too much clearance between the clip and the groove, causing deformation of the clip. I machine these types of shafts all the time, and only a few thousanths clearance is all thats allowed. I think if you inspect the shaft groove(s) and clip, you will likely see much more. Below an excerpt from an engineering article.....“We suggest the groove be wider by a few thousandths of an inch than the thickness of the ring, so we can ensure the installation will be done properly,” Moskalik explained. “However, if the groove is too wide, too much axial load to the outer edge of the ring will cause it to dish over if it isn’t feeding against something.”
The factory grooves in an R3 trans are quite shallow. The circlips are kinda dainty as well.
