So Speedy, you are stating this posted claim from Progressive is BS?!?
"Our 444 Series Shocks feature a proprietary patented Frequency Sensing Technology (FST) that has the unique ability to dynamically adjust damping as you ride; what this means is whether you’re hitting the small or big bumps in the road, the shock distributes oil through ports accordingly to soak up the hit making for an ultimately comfortable ride. A top mount threaded preload adjuster allows for fine-tuning with a simple twist of the cap."
If it is similar to the
Reflex Technology system used on Monroe shocks. Seems to work well enough and much smoother ride than my Koni Sports on another version of same car.
GT-GAS
Monroe GT-Gas with exclusive Reflex Technology delivers excellent vehicle stability and handling without compromising driver and passenger comfort.
Product features
- Exclusive twin disc design
- Teflon banded piston
- Multi-lip piston rod seal
- Superior hardchrome piston rod finish
- Nitrogen gas pressurised
- 3 year/60,000 kilometre warranty
Product benefits
- Firmer and safer handling with no compromise on comfort
- Low friction, long service life
- Improved retention of fluid and gas
- Increased seal durability
- Optimum fade-free performance under all conditions
The ride characteristics experienced with any suspension set up usually means an inescapable compromise between comfort and handling. In general, good handling requires firm damping from the shock absorber, while maintaining a comfortable ride requires a shock absorber with softer damping characteristics.
The design of Monroe GT-Gas with Reflex technology has a refined valving system which maintains excellent vehicle stability and handling whilst delivering a high level of comfort for all vehicle occupants. This has been achieved by the introduction of Twin Disc Technology a valving refinement that is present in both compression and rebound.
On compression at low piston speed, the revolutionary disc valve set design partially opens to provide limited oil flow. The result is a firm and stable manoeuvre when taking corners at low speed, or changing highway lanes.
With increased piston speed due to bumps, potholes, sharp cornering or emergency braking at high vehicle speed; an intermediate disc is activated. This provides an immediate increase in oil flow resulting in increased vehicle stability and safer road handling.
On rebound, the new twin disc design features a unique scalloped intermediate backing plate. This allows the valve disc to flex as the piston speed increases, metering the oil flow as demanded by the driving conditions.
The outcome is a cushioning of harsh road conditions with superior safety and control.
