Al Burdon
I recently replaced the indicator relay with a self cancelling one.
When patching into the rear brake wire I disconnected the ecu while the ignition was still on.
This caused a ecu fault light on the dash which disappeared after 3 cold - hot cycles.
The fuel level and distance to empty subsequently read Zero and would not reset.
The low tank warning light still illuminated.
I have checked all connectors and found no issues.
Today I removed the fuel senors connector at the tank and reconnected it.
The ecu warning has returned but also the gauge and range to empty has returned.
I don't have an obd2 connector yet but I am assuming the remove and replace had reset the ecu for the fuel sensor input to allow correct calculation from the output volage of the sender.
I have ordered a obd2 connector and cable. What software will allow me to view and reset ecu faults.
I don't need the abilty to load different maps at this time.
