This evening I tried to refit the clutch/engine cover and cannot get the actuator arm to link into the central clutch pin, then manual says you might need to make several attempts.
I have tries several times and it seems to connect but when I put the actuator arm on and move it there's a click and the arm jumps around.
I'm sure its just me but there's tears of frustration right now. When I line up the cover initially I need to put the clutch arm on and give it a slight tweak and the cover slots on beautifully but while messing round with the arm its seems to disengage, I also cannot see the alignment mark on my actuator it I get it wrong I have to remove the cover again and re-position the central pin and the actuator arm. I suspect i need to refit the flex spring to keep the pin pushed forward as I deliberately left it out. Thinking this may have been a mistake.
Any suggestion?
