Great to hear but excuse my ignorance...how would you describe the difference? Can any Triumph tech fit these for me...Just collected a 2017 R3 ( traded my 2015 that some tow rag stole some parts off)
Thanks
The main differences I noticed that stood out the most were:
1: Going over expansion joints, stock felt like a kidney punch, after putting on 440s/444s you feel the bump but it's drastically reduced and bike doesn't hop over it anymore.
2: When hitting a bump midcorner the bike won't change its line as much if at all, it'll just soak the bump but the tire stays on the ground so it doesn't hop out sideways slightly like stock will.
Overall it just smooths the ride out, and takes the sharpness off bumps but does it while preventing you from bottoming out, the bottom out is what causes the kidney punch feel, it's a result of too little high speed compression damping stock.
Higher tier shocks then progressives like ohlins and Wilber's do the same they just do it better with more adjustability to tailor the damping to your local riding conditions (track, good streets, bad streets, etc).
On small bumps/low speed compression events I found the 440s exactly right, perfect really. It's the pot holes/bigger bumps/high speed compression events the Wilber's really stood out vs the progressives.
