OEM are a bit pricey as are almost all Triumph bits but I can say that they look good and work well. Between the Eastern Beaver relay kit and OEM fog lights - visibility at night is no longer a problem!
Six, the lights are attached to one of the bolts from the radiator, you can adjust em side to side or up and down, they come with a 2 way switch for the halos or the lights, had them for about a year with no problems
I have the same lights and attached them to the indicators using existing mounting holes and longer bolts. They can either go above or below the indicator stem.
