Looking at the link from Progressive, it doesn't look like the 444's come apart the same way but I could be mistaken. Would you use that tool on the bottom of the shock, because the top is the adjustment end and is threaded but I don't believe that you can thread it the whole way off either ???
Generally, dive in a motorcycle is not a problem. Running out of suspension at either end of the shock travel is. 196)
Shock travel should almost never be controlled by the shock. Travel should always be controlled by the spring. 197)
Shock damping is just there to provide as little damping as required to keep the chassis movement from over shooting and bouncing. Shocks are not there to control total travel. 198)
Shocks have two types of resistance in compression “low speed damping” and “high speed damping”. High speed damping controls when the tire hits things like a speed bump. Low speed damping is things like a big dip in the highway. Extension damping only controls bounce or overshoot as the tires recover from a bump. Think of extension damping as the thing that only controls the spring. Compression damping controls the ride. Most of the time if you take the spring off the shock and pull in and out with your hands the resistance of the shock should be about the same going in and out. If you end up with way more of one that the other you must be trying to cover one problem with some other problem. Harley, on the Low bikes, is trying to cover up for too little extension travel with too much extension damping. Ride fast in fast bumps and the chassis will jack down or lower as you go thru the bumps. 199)
If, when trying to follow the above rules, you end up with too tight of springs for comfort then you do not have enough suspension travel. Add shock travel and start over. 200)
There is no such thing as upgrading springs. What you can change is spring rates and preload. The trick is knowing what direction to go. It is impossible for the shock guys to help you if there first question is not “what problem are we trying to solve”. If you don't know what the problem is. You can't answer his first question. I was horrified the first time I rode my 2007 1200 Low and have since spent about $600 getting parts an pieces off e-bay to have parts to test with. I have not found the front suspension that much of a problem. The rear was a mess from the factory. 201)
For a great schooling in suspension design, watch the moto-cross pros on TV and then reread the above rules several times during the program. Every lap will make this more clear. Google “Motion ratio” “shock tuning” “motorcycle shock tuning” for plenty more info. 202)
Harleys try to break every one of these rules. Follow the rules and all is good. 203)
Generally, there are only 2 choices for shock springs, heavy and light. Although I have not looked in what Ohlins and Penske offers, Works is the only company that offers Dual Rate springs for shocks. But from my experience with Works Pro Racers, they are only guessing. Progressive does offer different spring rates for different lengths of shocks, but tuning the spring rate is limited to preload changes. Progressive has admitted to me that the shock valving is not changed, only the spring is changed from heavy to light. 204)
Since our choice of springs is so limited, so is our ability to fine tune our suspension. The other big part of the problem is that most bikes with twin shocks are not considered hi performance, and therefor the aftermarket companies are not putting any effort into making good suspension for our specific bikes. 205)
So it seems to me that the greatest amount of adjustability to spring rates is offered by the Works Dual Rate springs. 206)
