Paul Bryant
I'll check that out Ian, as you say it's a bad connection somewhere.A loose fuse was a cause of the starting problem for me. I ended up putting a little blob of solder on one leg of the fuse to thicken it up a bit, and that did the trick.
There is a bad connection somewhere. Your job, should you choose to accept it, is to find that bad connection and eliminate it.
This tape will self destruct in 10 seconds.
Cheers.
