2016 Roadster with carpenter pipes
Discussion in 'TuneECU Source' started by AJ1, Aug 14, 2019.
  1. Steel
    Steel Resident Coonass
    6,427
    Featured Threads:
    25
    Media:
    9
    16,909
    823
    Cut Off, LA
    Ride:
    2012 Roadster & 2006 Classic
    It's all unnecessary, but most of us don't leave our bikes like they came from the factory.
    With the Carpenter exhaust and a good tune it really woke up my stock bike.
    Joesmoe likes this.
  2. 1olbull
    1olbull Riding Motor Since 1950
    Country:
    United States
    20,949
    Featured Threads:
    108
    Media:
    5
    17,298
    823
    Tacoma, WA
    Ride:
    2012 R3R "Kong" - 2011 R3R "YurMama"
    I meant the huge 4040s may yield more air than the stock engine needs and also require cutting up or removing the bearclaw.
  3. Tal
    Tal Living Legend
    3,549
    Featured Threads:
    38
    Media:
    2
    8,409
    823
    Christchurch, New Zealand
    Ride:
    2016 Triumph Rocket Roadster ABS A2
    i have 2780's....cut away bearclaw....jardine headers and cans and dyno tune to gell it all together....works well.
    My way of thinking is .....good air intake...must have good exhaust gas release.....makes the bike relax and breathe...and dyno tune to get the air/fuel correct....she will run like hot chocolate!
    You have the pipes, now choose your air intake...Ramair is great as are K&N's. Add Power Commander v which helps the tuner get things right. If you ride your bike in different altitudes, then you can get auto tune on the PCV...this will let the tune alter the fuel intake as you encounter different air pressures.
    If you dont want to cut the bearclaw, i would choose ramair as this will live under the bearclaw...snug fit.
    Joesmoe likes this.
  4. Steel
    6,427
    Featured Threads:
    25
    Media:
    9
    16,909
    823
    Cut Off, LA
    Ride:
    It's always better to have a little more, than not enough for what the motor wants, especially if you have your rpms higher than stock. And the huge chrome bearclaw is hideous.
  5. AJ1
    AJ1 .020 Over
    25
    Featured Threads:
    2
    20
    3
    Princeton
    Ride:
    2016 R3R
    Thank you. Will this fit under the bear claw ?
  6. Steel
    6,427
    Featured Threads:
    25
    Media:
    9
    16,909
    823
    Cut Off, LA
    Ride:
    No, the bearclaw has to be trimmed or removed.
  7. AJ1
    AJ1 .020 Over
    25
    Featured Threads:
    2
    20
    3
    Princeton
    Ride:
    2016 R3R
    Mine is stock engine.
    Will the 2780s fit under the bearclaw ?
    Also, which K&N components would fit for ATI and crank case breather ?
  8. 1olbull
    Country:
    United States
    20,949
    Featured Threads:
    108
    Media:
    5
    17,298
    823
    Tacoma, WA
    Ride:
    Yes indeed!
  9. Claviger
    Claviger Aspiring Student
    6,140
    Featured Threads:
    141
    Media:
    69
    9,011
    823
    Olympia Washington
    Ride:
    '14 R3R, '02 Daytona 955i
    I have a carp pipe tune that will work well once you've swapped out the intake to any of the options, message me your email.
    Joesmoe, AJ1 and Steel like this.
  10. TXtriple
    TXtriple SIC VIS PACEM PARA BELLUM
    Country:
    United States
    212
    Featured Threads:
    4
    552
    103
    Central Texas Hill Country
    Ride:
    2012 Roadster
    The 2780s fit fine under a bearclaw painted flat black. :cool:
    Joesmoe likes this.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
