Recommend Tune for 2013 Roadster ABS fitted with Ramair and Cat Delete
Thank you all for the information. With the information I was able to ascertain that the exhaust is stock and not TORS. I have contacted David Platt and will "fix" the cat issue for good. Custom Silencers with Performance Pipe. I will then do a re-tune. Any suggestions on the tune I should go with for this setup?
2013 Roadster with Ramair and David Platt Custom Silencers with Performance Pipe
David Plat Custom Silencers with Performance Pipe installed and the ECU programmed with:
20355 Baseline Dyno Tune 2011 - Thanks Martin_Brighton_Uk
This has made a grand difference!
Thank you all for your help with this.
