saltire
North East Scotland
2021 rocket 3 r
Hi i just flashed the bike for the 1st time everything seemed to go ok until i checked the error codes and i managed to clear the cruise control one , but my check engine light is now on with the error crankshaft position not adapted , it says to clear this adapt the crank position and then turn ignition of for 120 sec ! any one else had this issue .
Glad you sorted it out. You might post up the steps you took to help others with the same issue in future.
Engine Code P0315 error - SOLVED! I found the procedure here thread number 7 .
Some folks might find it a bit disturbing having to give the bike full throttle but it only happens for a few seconds , four times and in tune ecu it tells you to stop and close throttle then shut the bike down for 2 mins .All sorted .
