R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,451
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
TTS forgot to mention the use of the bottom tap in the instructions but that is why 2 taps are supplied
in the kit.
Trying to work out how the new clutch lifter piece is fitted,no mention in the instruction.
TTS forgot to mention a lot of things
I reckon you're confused because you have the old style roller thrust bearing and lifter piece that Triumph discontinued - perhaps TTS only do one lifter piece and it's for the newer pressure plate. With a ball bearing.
What is the diameter of the bore in your pressure plate?
Both the hole through the middle and the lip the OEM bearing sits against
Also diameter of your TTS piece
