ratsidecar
.060 Over
Hi, while my rocket engine is stripped down to have the TDSU bearings replaed and second gear and the detent mechanism replaced with updated parts from later rockets I guess this would also be a good opportunity to replace the pistons. I see that JE supply pistons for the rocket with either 10.5:1 or 11.7:1 compression ratio. I intend to have a TTS supercharger kit fitted to my bike by next year and see that the stage 3 kit they offer uses higher compression JE forged pistons.
I would like to know which pistons they use with that kit so I can have the correct ones already fitted to the bike to save some labour and time.
And on an otherwise standard motor apart from exhaust and filter upgrades I assume it would be wise to back off the ignition timing by 3 degrees or so through the rev range at larger throttle openings to avoid the risk of detonation as I will have to run the bike as is for a year or so till I can get the funds together for the supercharger.
