There are some small differences between them but If you give me a little time I could do the same as I did before and copy the values over as I did for the STD/Classics AFR's Table.
Have you got a PCV + AT yet or are you still thinking about it, if you have it then let me know and as soon as I have a few hours to spare I will do it.
Alternativly you can do it your self if you already have a PCV + AT and you have TuneECU software, It is just a matter of doing a Screen print of the AFR table in an TuneECU tune then marking out the common Trottle Postion % points and the RPM points on a Zero PCV Map's AFR table and work out the percentage difference on the points in between remembering that the PCV tables are upside down to the TuneECU tables. To do this you need to have your laptop connected to a PCV + AT to be able to create a AFR Table
