martinrl
OK - here's the thing.
Headlights are (in theory) designed to disperse LIGHT emitted from a known point (it's why all H4 bulbs are the same standard dimension) - IF the headlight reflectors/refractors are well designed then the light emitted is directed to where it should be - i.e THE ROAD. Most 7" reflector/refractors assemblies are pretty decent. And the H4 bulb was specc'd to fit 7" units.
- BUT - Now the LED "bulb" - ime they do not have a universal or particularly well defined point of emission. So whilst they may well put out more light - it simply is not focused correctly. This means they look really good in the car park next to your mate's bike but at night well maybe less so. If the aim of the headlight is to let others see you more obviously - then this is an ideal solution. But if you intend to ride at night on unlit roads - simply a waste of time and effort. You can be lucky though ime - most are crap.
The remote box is the LED driver. It is an electronic controller designed to make sure the LEDS receive a constant voltage and amperage. It is a GOOD SIGN. A LED "bulb" without this is almost certainly going to overheat and gate down the light output.
The Truck-Lite Phase7 7" is a decent bespoke LED headlight unit at a decent price. It has a very well defined beam for night work. But there are many.
I won't get into Triumph 5&3/4" units here - They are simply CRAP anyway.
I appreciate your input. I mainly want to be seen on the road, day or night, by other vehicles without spending a lot of money. I don't do a lot of night riding, but maybe when I retire I'm leaning towards complete headlight replacement instead of bulbs. There's not a lot of room in the factory light cans to squeeze all that stuff in anyways. I'll hold on to the originals as well in case it doesn't work out long term.
Given that I am 'stuck' with the 5 3/4 headlights, are fog lights a better solution for night riding?
