Foglight (Highway light) bulb replacement
I hope that doesn't cause issues down the line, all the power is funneled through the keyswitch. You can do a search here for "ignition issues" and find people who - over time - have had their keyswitches fail, leaving them stranded. The Eastern Beaver relay and bypass would give you even more light (as you'd draw power directly from the battery, no voltage drop) and also go around the keyswitch which may or may not fail down the line otherwise. Probably worth $50 and an hour's easy work. :)
Sounds like a plan. I'll probably upgrade with a kit like the one from Eastern Beaver eventually.
I had done a post some time back but got hammered by some for unknown reason. There is a 100wt bulb that has a small tang when removed is a perfect replacement, no problems with wiring, lens is glass, and 200 watts of light. they have been in my 09 Touring without any issues cost less than aftermarket and I can SEE unlike OEM.
You installed 100wt bulbs in your auxiliary/foglights? I went from 35wt to 55wt and after a few years it fried the wiring. I'm quite surprised you've made so long without failure.
The first thing I did with my R3T was swap out the stock bulbs with Sylvania Silverstar. They are easy to find in auto and department stores.
Whoa, I think I've been misled. Both of my fog lights have died since I got my '14 R3T and the dealer replaced under warranty without issue; needed to wait for lights to come in though. I was told they are some sort of "sealed unit" and that the entire housing had to be replced at $95 each or so; if I didn't have the warranty. So if you have swapped them out simply with the buld replacement, I must have misunderstood what the dealer told me. :oops:
2 H3 Xtreme White 18780-05 $68.00
- Shipping:$0.00- 1 PIAA H4 Extream White Plus Headlight Bulbs $49.50
Put these in as soon as I bought the bike ultra bright and ultra white. Same wattage as stock made in japan not china. Not cheep but worth it. Free shipping in USA took 3 days.
Fast eddy Sports
www.fasteddysports.com/
Featuring Affordable quality products with FREE Shipping US specializing in the New Triumph's, Metric and American Motorcycles. Featuring: Mustang Seats ...
Great guy to deal with also bought my D&D PIPES from him best price around.
Fast eddy Sports
Jag: Can you provide the PIAA part numbers? A couple of web sites say this is not a fit for the R3T.
For u Ksquared
Head light PIAA power sport bulbs part#70456 model# H-292E
Driving lights PIAA power sport bulbs part#70323 model# H-2655E
Though by the time you've "mentally spent" about $150 on PIAA bulbs the step from there to $360-ish for a full set of Truck-lite Phase 7 LEDs with reflectors and all isn't far. :)
For u Ksquared
For u Ksquared
