Ok today has been a busy day:
Got Avon Cobra fitted on front
Installed Ramair
Taking the bullsheep plastic bits out was a drama at 1st , i had a brain fart and was about to start chopping off fuel hoses but rang Hanso first and he set me straight , sorry for sounding like a grumpy prick mate , i tend to get frustrated easily when mechanical things do my head in. The only drama i had after that was removing the gadget that attached to the air intake , has a vacum hose and cable attached to it , i couldnt get the hex bolt out so i just hacksawed the thing of , woops.
When tryin to fit the Ramair the thing kept popping off until i realized you need to align the screws on the clamps so they are totally free from any sort of obstruction or touching any object . So then did the Bruce fix and zip tied them in,
Secondly who the **** thinks putting that engine breather filter on is a Cnt of a job ???? My fat hands had no chance of fitting in there , so i compressed the filter as flat as possible and taped it down , then i taped a long flat bladed screwdriver on top of it and maneuvered it into place using a second flat screwdriver while holding a small torch in my mouth !!! Once there i used a ring spanner positioned behind the clamp screw so it wouldnt keep pushing away while i tightened it , once tight i used the screw driver to carefully remove the tape and let the filter open up.
Run a 12 min tune , uploaded the Hanso map , reset TPS then another 12 min tune , started stitching her up as far as refitting the bear claw , thats where im having issues, the claw wont seat over the Ramair properly and keeps popping off the top rubber mount , is there somthing im missing here ?
Syncd the throttle bodies as well , they were out a good deal , running smoother now
