Working on an Intake project
Discussion in 'Custom Mods' started by Claviger, Apr 22, 2016.
  1. Claviger
    ClavigerHP Junkie extraordinaire
    4,791
    Featured Threads:
    111
    Media:
    69
    5,601
    823
    Olympia Washington
    Ride:
    '14 R3R, '02 Daytona 955i
    So...there are a lot of air intake solutions for the rocket so far. They all work, as expected. Not a single one, however, allows for the adjustment of intake runner length, or incorporates anything more than a nod to smoothing the intake air flow. This design will allow for simple adjustment of runner length in the drawing by shifting 3 surfaces, that's it.
    AS A RESULT, I have decided I'll go ahead and make a solution for the community, to be used with any of the variants of the piper cross PX500 filter. This will be a process, I have to get the 1st one made, fit it, make adjustments to the drawing, ensure it's out of the way of the knee etc etc. Pipercross doesn't have good drawings posted of their filter or backplate, but there are rudimentary ones. I give you the initial drawing, to be printed for test fitment and figuring out where I can take material out without compromising the part:
    Nat67, Sonofcorax, DEcosse and 2 others like this.
  2. Claviger
    4,791
    Featured Threads:
    111
    Media:
    69
    5,601
    823
    Olympia Washington
    Ride:
    So after pricing the original idea, its not reasonable to have it printed as it is, so shelving that for the moment, here are some singles that would be added to the Pipercross metal blank backing plate, they include a groove in the back for an O-ring and could be attached to the plate using some small self tapping screws, 2 or 3 will do the job:
    Nat67 and Tripps like this.
  3. Claviger
    4,791
    Featured Threads:
    111
    Media:
    69
    5,601
    823
    Olympia Washington
    Ride:
    And the final setup I'll build tonight, these are on order already, to adapt the RAMAIR filter using extensions that have a much better transition from the filter into the intake tract, two versions, 2" and 1", I ordered both planning on fitting and destructively testing to check their strength:
    2 Inch:
    1 Inch:
    Nat67 likes this.
  4. Scorp
    ScorpAdrian
    Country:
    Australia
    674
    Media:
    5
    532
    103
    Perth Western Australia
    Ride:
    Rocket III Classic 2006
    Watching with interest :)
  5. blip
    blipSupercharged
    Country:
    United States
    209
    Featured Threads:
    3
    78
    28
    Ottawa, Ontario
    Ride:
    2014 R3 Roadster
    My interest is certainly piqued. Good luck!
  6. Rocket3Pilot
    Rocket3PilotSupercharged
    Country:
    United States
    475
    Featured Threads:
    6
    542
    103
    Waynesboro Virginia
    Ride:
    2013 Rocket III Roadster
    Beautiful cad drawings! I'm curious about what you call runner length? Are you considering a variable height velocity stack? If so, I don't think there's anyway to get one in the RamAir as it barely fits under the bear claw now.
    Nat67 likes this.
  7. Rocket3Pilot
    Country:
    United States
    475
    Featured Threads:
    6
    542
    103
    Waynesboro Virginia
    Ride:
    Also, just one other thought, since you're obviously concerned with turbulence at the inlet, cut the thickness of the stock throttle bodies out of the inside bore from the bottom so that when you slide it on, it stops at a shoulder and effectively creates a smooth transition. Just a thought. Wish I could CAD draw but it makes the artist in me crazy? o_O
    Nat67 likes this.
  8. warp9.9
    warp9.9Pocałuj mnie w dupę
    7,536
    Featured Threads:
    9
    Media:
    14
    7,955
    823
    Forest City Illinois
    Ride:
    07 Rocket
    The 504D is what I used on mine of course no fancy CAD stuff available :D
  9. Claviger
    4,791
    Featured Threads:
    111
    Media:
    69
    5,601
    823
    Olympia Washington
    Ride:
    Your setup is what was on my mind as I was designing it @warp9.9 , but I wanted to have big fat stack rolls on the top.
    @Rocket3Pilot they are a butt fit already, and will use a stretched 60mm silicone coupler to attach, so there will be a smooth no lip transition as its drawn. Fitting under the claw was never intended, but, that will be part of the tweaking, getting it positioned just right so you don't need the claw for appearances.
    For the adjustable length, I have to draw it up, but I have a concept that will use the red setup as the basis and uses a sort of shim to add length, the tough part is that as they get longer, they will have to curve so you don't have the whole thing hanging way out off the side of the bike. To get the right curve I need one in hand first, and to do that, I need to get part cost down significantly first.
    The next step is the wait game on shapeways and shipping... The patience part, not my forte.
  10. EasTexRIII
    EasTexRIIIUneasy Rider
    Country:
    United States
    6,560
    Featured Threads:
    21
    Media:
    16
    9,908
    823
    Tyler, Tx
    Ride:
    05 Rocket III, Trek Road bike, Trek Mountain bike
    How firkin funny! I noticed your nameplate @ the bottom of the engine under the triangle emblem, as I have the exact same emblem, also removed from the backing plate it came on, in the exact same spot on mine (NOT that I'm trying to compare my wimpy stock engine to yours)
    Just thought that was funny how easily that caught my eye
    Nat67 likes this.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
