rainman
Seabee can do
Stupid question...should this be done if you don't run dark side? The manual states that the drive shaft is maintenance free and only the bevel box fluid levels need to be maintained. I haven't removed the bevel box from the drive shaft to grease the splines. I grease the wheel driven flange with moly at every tire change but now I'm wondering if I need to do more? Or am I looking after things correctly?
Thanks
If u don't you may wind up with the same problem I had a few years ago where my final drive went out I had not greased the back end of the drive shaft I had bout 54000 miles on my r3t I have pix on here somewhere on what it looked like so it would be wise to grease it all at every tire change
