Rocket Scientist
Grand Exulted Poobah
- Joined
- Sep 27, 2009
- Messages
- 6,832
- Location
- Spring Lake, Michigan
- Ride
- Black 05' Rocket III standard
What is all involved in pulling the pan, I figure the 3 drain bolts and all the other bolts holding the pan. What about all the other bigger bolts? Doing 10k service and want to see how much crap is on the screens.
Once the oil is out there are about 20 or so 8mm headed bolts around the outside and a couple towards the middle. Pay attention as one of them has a little copper washer on it. I'm not sure which one as I noticed it later. I took an educated guess and it doesn't leak. It doesn't show the washer in the manual. I'ts hard not to tear the gasket and they are $15.00 ! If your looking at the manual I believe the big bolts you are seeing are exposed after the oil pan is removed. They hold the mains latter. You shouldn't have to mess with them. I only dropped my mains latter to make sure there were no pieces of broken bearing sitting on top of the windage tray per warp 9.9's suggestion.
