Sump pan
Yellow 21 mounting bolt holes
red areas debris can collect in the one with the x is up front under the clutch basket.
green sump screen top plates.
under side of sump screen yellow is the drain plugs you pull when draining oil.
red is the galley passageways that will still contain oil after a change unless you pull the pipe plugs.
Caution if you pull the pipe plugs do not over torque when re-installing these are NPT tapered pipe plugs) and you will not like it if you crack the sump plate!!!!
below is a shot of the screen under the plate this is where the machining swarf from the engine gets trapped all engines have machining swarf when delivered its not bad but it is almost impossible to get all the machining swarf out until she has been run a while and you drop the sump and clean these screens which is where the oil is drawn through before going through the engine
below is a shot with the screen off so you can see the drain plug. the two screen have drain plugs and the tank has the long drain plug.
