granny davis
.060 Over
australia
Kawasaki vulcan classic , and now a Triumph rocket tourer 08
:confused::cool:Has any body had any problems with their neutral switch meaning you put the bike in neut light comes on then it goes off then you put the side stand down motor stop's and does it often enough that the engine management warning light comes on. Or every thing work's as it should turn the bike off go out to the bike later on turn it on and what do you know neutral light not on again if not the switch maybe something more sinister bike will be going in to the shop in a couple of weeks i,m just curious begood and ride safe every body
Pull the gear position sensor off and give it a clean. Also clean the spring loaded post inside. I also gave a little squirt of WD40 in the hole the post comes out of. Fixed mine.
When you put it back on tighten the bolts just enough to hold it but allowing some small movement. rock it from side to side a little with key on and see if there's a spot where the light stays on better - if you get my drift. Tighten it up in that position.
+1 on above...........probably needs tweaking to find the sweet spot
mutt
:D:cool:Thanks was on my way to get the wd40 and the neut light started working as it should when that happen the engine management warning light went away so while it appears to be working at the moment iam not game to touch it.So canberra the next time it starts to play up i will do what you have sugested many thanks
My joy did not last long in the end i took the bike to asian charlie turns out the gear sensor is knackered while he waits for the new one i,am going to get him to service and tune t-rock as well
