I have been having an issue with starting the bike.
Battery is good, starter relay is good, starter motor is good, crank position sensor is clean, all connections have been well cleaned and re assembled.
What happens is some times I go to start the bike and it will fire up straight away just as expected.
Other times (totally random) ignition on, pull the clutch, hit the button, I hear the relay switch, I hear the starter solenoid activate, but the engine will not turn over.
If I put the bike in gear and "rock" the bike a little, it will start up straight away.
Can't figure it out, any suggestions ?
