I don’t want to stray too far from the original topic, but... on the subject of injectors.
This is where you run into a couple of limitations of using the stock ECU, but you can get around it, for those who want to pick their own parts.
The two factors you cannot adjust that would be amazing are injector dead time and the enrichment fueling table.
Injector Dead Time: this is the time it takes for injector to go from closed to open, a period of time where the ECU has commanded fuel to flow but it’s not yet. Getting this number right is important, if effects fueling at all conditions.
If it’s set to a number lower in the ECU than the actual physical dead time of the injector you’re using, the values in the fueling table will be higher than they technically should be because the injector is still opening while the ECU expects it to be spraying fuel.
If it’s set higher in the ECU than the physical opening time of your injectors, you’ll need to subtract fuel from the tables slightly because it takes the injector less time to open than the ECU expects.
As a result, you may replace 300 cc injectors with 400 cc injectors, and do the math and reduce fuel tables by the percentage. Start the bike and it runs too lean or too rich. It’s because of an injector dead time mismatch. You can cover up the problem by getting a FULL remap, optimally though, you be able to set dead times. Some of the other effects are when does the ECU start injecting? If dead time is off, the start of that injection event will be miss-timed.
The 550s I have are a VERY low opening time. I knew that going in so reduced the tables by 38%, sure enough it ran my stock motor back in 2015 pretty **** well setup like that.
Here’s how some companies size your injectors:
Injector flow (in lb/hr) = (BSFC x Engine HP) / (number of injectors x max duty cycle)
Examples:
(0.65bsfc x 300hp) (3injectors x .8duty cycle) = 52lb/hr
That’s how I KNOW 53lbs is enough without a PC-V using TuneECU, the rockets not .65 bsfc, more like .5-.55 But how claviger?!
(270 x .5) / (3 x 1) = 45 lb/hr (472cc)
390cc stockers @ 100% duty = 470cc...
Makes sense right?
Now enrichment... another time this is already long.
