Help 2008 r3 touring not starting
OK. Spark is verified, so now it's fuel or spark timing. Clean the crank angle sensor and then make sure all the electrical connections are clean and tight. It would be a great help to know if the fuel pump discharge pressure is correct. Do you have a fuel pump pressure guage?
Thanks I'll try to get to that, but I still want to make sure I have the evaporator can hoses right, and reset the codes first. I can hear the pump coming on and shutting down I guess when it's up to pressure, I have a fuel gage somewhere, but at least I can disconnect the hose to the injector rail and see if I have flow. Thanks for the quick reply 👍 my charger wasn't working, had to borrow one, have 1 on order shumaker
The pump pressure is 43 psi (or 3 bar) downstream of the regulator. If the pump (or regulator) isn't delivering that pressure to the rail you'll have starting/running problems.
