HellFire
Legend
- Joined
- Aug 16, 2008
- Messages
- 4,518
The bikes it makes the biggest difference with is stock bikes. Since it doesn't change anything with the fuel, and you are still running stock exhaust and intake that doesn't require any mods to the mixtures, all it does is trick the bike into thinking it's in the gear programmed for the most power delivery.
4th and 5th gears are set from the factory with 7% more power than 1st-3rd ... the bike just thinks it's always running in 4th or 5th ... all the time.
I would take out the secondaries just for the quick throttle response, but you don't have to. If you want to leave it stock just put in the GiPro and enjoy the added power in low gears. As long as it's installed correctly and working as per designed, you won't be disappointed.
