Electrical gremlin
Great, thank you. I'm no scientist when it come to electrics but will give it a go and see what happens. Many thanks for your help
Mine is the same, once warmed up the hight beam indicator shows. I can live with it. That is the cost difference between the Chinese ones compared to the branded. Worth the blue light on at times for the $$$ saving.
Reactions: Jag
I'm going to give the inline diode solution a go Scorp, if it works i'll let you know so you can cure if you wish
1kiloOhm resister between the high beam positive and ground sorts it...and you only need to do it in one light.
With an in-line diode you’ll need to do both Lights and they will need to be rated for the current drawn by the led plus a safety margin. A resistor will cost less than $1.
