BULL**** the big ROCKET will scrub the rubber of those soft lightweight tires
Ya think worse than it does already with the Exedra Max? :p
I found a pix of you riding . . .
Keep on going even though it's mostly all over my head , I can read INBETWEEN the lines and make a decision if it's a good idea or bad , or just not worth it.:)
So you guys was saying tire need to beable to take the weight.
What size is the rims on a Boss Hoss, if I can find a custom rim that I like and get the guy to mount the hub so it can fit into the shaft and get the low profile 240 tire? How would that work? Or it's not that easy?
This guy that I found that's going to to all my parts all in aluminum, and if I'm going to ask him to do this for me I need to know if it's possible and a good idea, and running this threw you guys I want to beable to explain excacly what I want.
He' going to make my other tank se metric so both sides of the tank looks the same, the other side might flip down as a glove box with lock, or make a air filter on the other side and connect so I can have a big cone filter on both sides of the tank and fit the tank around it, with a fake scoop on top of the tank, the tank when finished will hold more gas:) ok say I'm crazy:)
Just a PSA, for Americans, if you order your BSTs from the U.K., they are "on sale" right now for 3300.
Pound to USD conversion rate is in our favor at the moment and we don't pay VAT so if your planning on doing it, the time is NOW!
There are a couple of 18" tire sizes. The VRod has an 18" rear. The M109 uses 18" front and back. Being a heavy cruiser with a good bit of torque also, it needs durable tires. So there are options.
As for those intakes, they look small for the size motor we have to feed.
