theharleydr
just finished tuning my 05 151 lb ft and 145 hp
down for a while with clutch issues, the roller bearing update is every thing!
Also stator was out with a grounded leg.
While motor was out shimmed valves,wrapped headers, added a 3 to 1 pipe and tuned to 13.2-15.3 AFR throughout rpm range.
2 dyno sessions and 213 miles later the exhaust cam breaks at #2. Looks burned and galled.
Picked up an 06 head and noticed the oil feed to the cam ladder is jetted as opposed to the open port on the o5.
Any ideas why only that lobe would burn ?
34444 miles on the clock.
rebuilt trans with issue 1 update at 19k.
new clutch lifter piece and wafer bearing @24k
new clutch pack and wafer at 29k
stator and clutch upgrade at 34k
now a head and cams.
