Wow, just installed my GI Pro
Thanks for the post back. I keep thinking about it. I have seen a couple of pictures posted here showing a guy leaned into a curve with a CT and the contact patch is pretty large. I don't expect the weight or power of the bike to be more than the tire can handle, my R3T is big but not car big. When I wear this new Metzler out I may try it. I can always start taking my Trophy or my FLT to my classes. I may wait until I run into one of you guys that are doing it and watch the bike going down the road an see for myself what it does. With the cost of tires for bikes, anything that can save some cash is good in my book.
Tell you what, BW. Just as soon as I can burn through the Metz that's currently on my new ride, I'll be mounting a CT on her and when I have it done you're welcome to come up to Jersey and check it out for yourself. Of course, that will allow me to assess the GiProon your bike at the same time.
I don't see why you would necessarily need Tuneboy or anything for that matter. It depends what you want to accomplish. You definitely don't want to lean out your fuel mixture and then advance your timing to the point where you get detonation.
Don't the standard and cat delete Triumph tunes partially close the secondaries in the lower gears as well as retard the timing? If so, wouldn't the GIPro tricking the ECU to read a higher gear cause the secondaries to fully open as well as advance the timing?
If you have 20226 (TORs/cat bypass) installed, fooling the ECU to read 4th or 5th all the time will only open the secondaries 100% above 4000 RPM. If you load 20222 (standard) exhaust, fooling the ECU to read 4th or 5th all the time will open the secondaries 100% at all RPMs. This isnt the case for ignition, since all the ignition tables in 20226 are the same (except for neutral). For 20222, the table for 3rd-5th is more advanced than those for 1st and second and also more advanced (in spots) than all of the ignition tables in 20226.
Huh??????????????????
You have to know what tune is in your bike and what that tune (and others you might be interested in) is telling the ECU to do with timing and secondaries in each gear.
Well don't get upset, but you can accomplish pretty much the same thing with the gear sensor mod, but you don't get a LCD display to tell you what gear your in. With Tuneboy you copy the timing maps from 4th and 5th gear to 1st through 3rd to accomplish the same thing.
Doug is correct, depending on what base tune you have loaded, if you haven't removed the secondaries, they may still be closing. Triumph off-road exhaust and aftermarket exhaust tunes actually close the secondaries more to richen the fuel mixture instead of adding more fuel.
Also there have been some claims of 160+ hp/torque. Both numbers I haven't been able to reach with Tuneboy, PCIII, Jardines, Nev's Cams and Uni filters. Which leads me to believe there is some hype.
How much to buy and install Nev's cams? Is he offering connecting rods, pistons, valves, etc.? My dealer said he heard about someone in Canada with this stuff.
I bought the cams almost a year ago when the Aus $ tanked. I think they were around $700. I installed them, with a lot of help from Toystoretom. About the only thing I picked up is that the bike reaches red line about 1/2 second quicker now according to the dyno. HP is a wash.
