BillB
Turbocharged
Can you map differently by gear with the TuneBoyLIVE? - I don't know about you but I do NOT use the throttle the same in each gear.
In theory you could had 10 different maps in a PCV - One per gear and the "Map Switch". I now have a decent baseline (per gear) via the A/T. After my run home/back - I will be leaning out 5th a bit around 3000-4000rpm and under 40% throttle. I'm not doing it now before a long run - just in case I screw up.
90 miles to empty the tank - Well done!.
@barbagris Does your standard have a gear indicator on it? That map for each gear thingy sounds interesting but I don't know if it would work on a touring. No gear indicator on my 13 touring so how would it know what gear I was in?
