In the process of checking valve clearance and replacing valve cover gasket. The gasket started out seeping a little bit of oil on the right hand side and then it curled and really started to leak. Once I got all the stock ductwork off I found several areas where the gasket has been leaking. This is my second time checking the valves and have bought the Ramair. No way am I going to hassle the stock system twice. Do plan on taking the valve cover to work and check it out for being true and flat. Yes I thought the same that my oil tank was leaking but it is not,turned out to be just the valve cover gasket. Have bought and plan on replacing every seal on the valve cover including the seals around the bolts this time. This gasket lasted 25,000 miles so it was time for a check anyways. First check did at 10,000 miles and no leaks were found. I followed the manual to the letter on replacing the valve cover gasket but believe the cover may be off a bit. Easy fix.
