Torque addict
Didn't realize the valve was customer supplied. Thanks for confirming it's a BLV and not a BOV. That's what I wanted to know. I'm thinking I probably won't hook up the vacuum line then. Will probably pressurize the custom air plenum it's on though to make sure it works. Call me paranoid I guess but it doesn't need any more blown head gaskets!It is a BOOST LIMITING VALVE, and the turbo is an Aerocharger with variable vanes.
The ONLY contact I have had with this bike was two owners ago. I was asked to perform a compression test, install a customer supplied boost limit valve, and hold the bike until it shipped.
For more details, contact prior owners.
And thanks for your explanation warp. I remember talking to you on the phone too before I bought the bike and you were trying to explain it to me then. I've since researched it even more and understand the difference. Just wasn't sure what I had. It sure looks like a BOV instead of a BLV from all the pictures I can find on-line.
TO rocket said:The engine number and the vin number are different.
Battersea said:The numbers don't match on mine and has known history. I don't think you need to worry.
Thanks guys. I won't worry about it. I'm sure it must the original engine then. I just wouldn't have figured that Triumph marks them differently. That means only the original owner can be 100% sure it hasn't been replaced.
