vindex1963
Turbocharged
- Joined
- Aug 3, 2019
- Messages
- 887
- Location
- Payson Arizona
- Ride
- 2006 Rocket 3, 2015 Victory Cross Country
The rest of my lighting works fine. Replaced bulbs, removed side cover and checked the yellow/black wires and plug. Pulled the plug apart and plugged it back in. Fuse #10 is fine. (see I searched!!)
I removed the small parking light bulbs from the headlight when I added the LED headlight so I don't know if they work. I see many posts with this problem and unless I've missed it I can't find anyone that found a solution.
Would removing the small bulbs in the headlight break the circuit causing the tail light running light and license plate bulb to not work? I wouldn't think so....
I added red LED strips to the back as a running light tapping into an unused keyed plug under the tank so I have something back there.
