Dennsell
Top Fuel
- Joined
- Jul 5, 2009
- Messages
- 1,860
- Location
- Kawasaki Japan (Perth WA) (GY - UK)
- Ride
- Bonnie T 100, unfortunately not Rocket lll Country
When you fit the Cat eliminator and the new Cans it is better to leave all connections and clamps loose, this helps when you are trying to line up and start the mounting bracket bolts..
Once everything is in place then go around and systematically tighten all fittings.. I also found that a little light oil inside of the Can tube gaskets helped to make the slip over the pipes.
