sawnoff stu
Standard Bore
have had nothing but trouble with this beast. bought second hand an rode before buying. left outside for couple of very wet days then the mrs an myself got all togged up for a good ride out... reversed on to the road. started engine, pulled away then it died and wouldnt start. checked electrics fitted new plugs still no go....six hours later after getting very interment with electrics with no joy. was ready to set it on fire an walk away. gave it a few more attempts then thought why can i not smell any petrol..... had half tank an could hear pump doing its thing. opened tank cap dipped an tasted fuel.....it is petrol. pulled pipe off and smelt the leakage...no smell......tasted it an it was water.. found the cap ring had not been fitted properly an couple of the screws were cross threaded stopping the cap sealing. repaired these .drained tank, dried it out.. refitted tank refilled with real fuel ..it shuddered into life......rode for a while then started missing... mate plugged it in an said an injector was misbehaving. looked at the cost of an injector from triumph an nearly died.
question here is....honda civic injectors look the same and as long as the resistance is the same in the unit.....anyone know if they will work as new they are only 17 quid
cheers stu
cheers stu
