Yes sir, just a regular OBDII port on the bike, however you will need a usb/obdii cable with an ftdi chipset.
This is the one I got-
https://www.ebay.com/itm/TuneEcu-compatible-KKL-lead-Tune-Ecu-includes-Android-USB/282262182326?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Go here and read up, you should be good to go.
TuneECU.org
I used tune 20368
Nels_Tune_TORs_RAMAIR_Final, TORs, which is in the Triumph database on the above site.
I could have made adjustment using TuneEcu, but I figured Nels and Power-Tripp had a better idea than I do about what might be close enough until I get it on a Dyno. I haven’t ridden it yet due to the weather, but getting ready to find out shortly the temp is 38F and rising.
BTW, the tune also let’s me start with the kickstand down and the clutch out in neutral now.
Good luck!
