Boosterplug for 06-09 Rocket 3 Classic
Booster plug opinion:
Would seem Booster plug does not disagree
What about a Power Commander ?
  • Well, for 95% of all owners, the BoosterPlug is a better solution. Simple solutions can be brilliant.
  • The factory's technicians actually know what they are doing, and the BoosterPlug works with the ECU, not against it. The BoosterPlug will just add the little extra fuel your bike wants for optimum driveability and performance. The factory guys can't do this due to legal restrictions.
  • With the Power Commander or equivalent products, you can change almost anything, and most of these products will shut down closed loop operation. With so many features to change, it really takes a very experienced guy and a lot of Dyno time to get things right.
  • Most Power Commanders are never correctly setup, and the simple BoosterPlug will actually outperform 80% of all existing Power Commander installations, because the BoosterPlug is based on the very good factory map, and will just make the air/fuel mixture slightly richer where you need it.
  • If your bike is a real hardcore racer with sharp camshafts and big bore pistons etc. you may well need the Power Commander. If you're like most owners that ride your standard bike, or just fit other air filters and exhausts, you're better off with the BoosterPlug.
  • More details on the BoosterPlug vs Power Commander in the FAQ section.
That there sums it up for a shed load of riders!
