barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
Scott - Duly noted. Let surgery commence.Ok just noticing this and starting to read but part number T1260203 is just a rubber pad for absorbing shock its what fits under the chrome plate on the clutch cover, which you will not need to take it off the cover. So not needed. Oh and part number for lifter piece is correct. Really you should open her up as your steal might be fine as well as the fibers. But if you plan on refreshing the clutch then fibers and steels, cover gasketand, the new style lifter piece. Also your removing the clutch basket get a nut. This is a good time to verify which detent wheel you engine actually has. Since you won't or can't open her first lifter shaft is not to pricey. I have never had to replace the O-rings on the water pump. Mr. Hunt clued you in on making a clutch tool. Coming apart you won't need it if you have air and a impact wrench. To be honest I use the impact wrench to run it back up.
Now another push for opening her up first. Reason being what if your 08 is like the clutch video going around? You get all the parts and find out you have a 05 clutch like the 08 classic in the video. You stuck returning pieces and ordering different ones. And in 3 hours of wrenching you know what you have and need. In reality you could only need the spring, a new cover gasket, and the basket nut. After all its acting up I know you not riding it anyway!!!! RIGHT!!!!
Adding nut, removing rubber thingy.
