OKEY DOKEY- As I need to persuade Triumph Spain to sell me parts (the local dealer won't - yet!) - or will need to order elsewhere.
A plea to the R3 cognoscenti (esp the clutch master
@warp9.9 ) to check my parts list - PLEASE.
VIN SMTTLC10359381271 - Supposedly a 2009 model - but from the ECU date of August 2008 it might be an early one.
Engine number 3372883
So as I see this
1) Remove radiator - No service parts. But I will fit SAMCO's - if SAMCO deem to reply.
2) Remove Water Pump - Service part - O-Ring O RING WATER PUMP SL 3600160T03 Replaces 3600160-T0301 - but I'll get a Seal, Water Pump Cover T3600161 too.
3) Remove front cover - Service part - Gasket, Clutch Cover Outer T1260203 and Gasket, Clutch Cover T1260107.
4) Remove Clutch - Service part - WASHER ID 22 OD34 T1171282 Replaces T1170282 and WASHER "C" CLUTCH T1179999 Replaces 1170091-T0301
5) Detent Spring T1190086 (I will get a spare to have dimensioned locally) and just in case Spring, Gearchange Return T1190016, and E Circlip T3500044
6) Lifter Just in Case. Scott
@warp9.9 help. (T1172023)
If anybody sees anything I have forgotten - please say.
Now a mini dilema. Special tool - Locking plate 3880025-T0301. Necessary?. If so Fowlers are saying it's not available. WoT list a tool - much cheaper too. Any other alternative?.
I am on the fence re friction plates and springs. I have no slipping, and I am reluctant to up the clutch pull really. BUT I never, ever, disregard advice.
Anybody know if MTC are available from a European (incl UK) dealer? - EBC plates any good? Stick with OEM?
