Well I have been running it now for a couple of weeks with Triumph download, it is lean but tolerable. I have ordered and received a new Tune Boy, will be adding it and making appointment for dyno tune.
After doing some more research I also just ordered o2 eliminator from Dyno Jet. I plan on removing and installing plug in o2 hole and attaching o2 bypass plug. I will use "canned custom" Tune Boy tune untill I get into dyno shop. I shimmed out bearclaw using 1/3" spacers and using 1/2" black foam heat duct spacer/tape glued to side of gas tank to fill the gap between tank and claw, it looks factory. The "air noise" using 3 k&n's only took 2 days to get used to [the sound of power!]. 8)
