2013 Roadster No Starty!
Triumph Rocket 3 Water pump Rebuild Kit
Sorry I haven't posted for about a week. Was waiting on some cooler weather to test in since we've been in a mini heat wave here. Well everyone here's the results of the testing:
I isolated the radiator and water pump cooling circuit and the pressure test came back holding steady with no loss at 18 psi after 2 hours. I isolated the engine and was getting 8 pounds after running at 18 PSI for 2 hours. Ran that test twice with same results.
Ran a compression test on the engine. Cylinder 1: 180 psi
Cylinder 2: 85 psi
Cylinder 3: 185 psi
CONCLUSION: YEP, BLOWN HEAD GASKET!
Cylinder 2: 85 psi
Cylinder 3: 185 psi
Run a leak down test, then you'll know for sure.
