2013 Roadster No Starty!
Does anyone know if a failed water pump has caused coolant to go into the cylinders or crankcase on a 2300?
The most common cause of coolant entering the oil system on a Triumph Rocket III (Gen1) is a failed water pump mechanical seal, which allows coolant to bypass the pump’s internal barrier and migrate into the crankcase. This is the primary failure point when coolant and oil mix. A bad head gasket would allow water into the combustion chamber when chamber pressure is near negative and that can be checked by pulling spark plugs and checking the tips.
The cooling system:
Water pump is: T2105432
The mechanical seal is not a replaceable part, the whole pump must be replaced.
Yep. . . That was what I was thinking as well. I'm being as cautious as I can to run the engine as little as possible. I may just go ahead and pull the tank tonight and take a look at the plugs.
I just want to make sure its either the head gasket or the water pump before throwing down more coin for a new pump or rebuild kit.
I will warn you new water pumps are nonexistent at least in the US. There have been a couple folk on the Facebook waiting on an alleged backordered water pump some waiting since last year. The last I read a dealer said they arrive in October but Im not buying it. Those production lines are long gone. There may be some overseas but a used one seems to be the best option if one can be located or having one rebuilt which has been resorted too also. FYI I'm in Kansas City near Gladstone.
