It's freely available in the TuneEcu site. It de-restricts the secondaries (100%) so full power and corrected fuelling is attained. The exhaust needs to be less restrictive to get the best but a Dyno chart accompanies the tune, overall better fuel consumption unless ridden in a sprited manner, well, didn't buy a Rocket for fuel economy, smoother power delivery and the roll on power has increased considerably in all lower gears. Don't forget to read your map first and save it, then just blow in the new one, engine tuning has to be spot on before attempting tune re-load, all done with TuneEcu.
Just had to tweak very slightly as all bikes are slightly different, for a more even idle but apart from that no problems at all.
I download 20050 map when I did the upgrades to my 2008 rocket classic. I was asking questions on what maps to use and was directed to tune ECU and the triumph cable. so I saved my map in couple places and installed the new map. i'm running the factory bypass and TOR off a 2005 rocket I bought used. I have some questions on it and loss in certain areas along with fuel mileage. slow off the line, above 3k RPM it just takes off and wants to keep going even above the rev limit if it could. it does have more torque and HP. I went from a 31-33 MPG in town and now I get 29 MPG. it wants to roast the tire off in all gears at most speeds at 60 MPH it was a wake up. just would like to get your take on the map what I can do or change to yes get some mileage back as it was nice for daily driving. the quickness off the line. I just thing the map works better for different app than what i'm running right now thanks.
