EasTexRIII
The Triumph 20226 tune has the secondaries partially closed. Look at the secondaries table in TuneECU. You can see how this lowers the torque from about 2300 - 3500 rpm in the dyno chart below. Triumph did that on purpose - probably to reduce the stress on the transmission. You don't want to open the secondaries open 100% in 20226 because it will run lean - the fuel won't match the air flow. Assuming you have the TORs and cat bypass, try the 20050 decel tune in the link. Unchecking the O2 box prevents the ECU from using the O2 sensor signal, that is, going into closed loop. The ECU uses that signal to adapt the fueling to keep it lean at low throttle position - for emissions. It does nothing above about 30% throttle. When you uncheck it, the ECU uses the fueling specified in the fuel tables. 20050 decel has some fuel added at low throttle, so under hard decel at zero throttle, the popping is reduced. It doesn't eliminate it completely but it's better than the stock tune. Let me know if you don't like this tune.
dougl:
Sorry to keep pounding on this, but let me please ask: If I don't install 20050 because I'm not concerned with the decal pop:
1. If I leave 20226 map alone, and make no other changes (stock air filter, TORS, No cat box) do I still need to uncheck O2 box?
(I wasn't sure if you meant for the O2 box to be unchecked on 20226 or 20050 or both)
2. If I leave 20226 map alone, and install RamAir, no other changes, will that cause harm to the engine from being too lean?
I'm not looking for more H/P from R/A. just get rid of plumbing purpose. But obviously not worth it if it causes harm to engine.
3. If that will cause no harm, but I will lose low/mid range torque - It would not be a good trade off to get rid of plumbing either.
I think I know what the answers will be.......... so if the RamAir will not be good for my purposes....... back to question #1
Sorry if I've opened up another can o' night crawlers!!!!!
