warp9.9
Pocałuj mnie w dupę
@motolink Hmmm so we can tell your linked up at least some. Might have to send a message to Tom Hamburg to see if he has a idea as the whether your have a problem in tune ecu. Does it list what map number is in the ecu. Have you tried to read the map that is in the bike? I have seen a few older bikes that tune ecu could not recognize the map. Of course I never thought to ask if them bikes could perform any maintenance work like the ISCV RESET. I do know guys wit the newer ECU's and new tuneboy maps can support the maintenance work with tune ecu but not read the map which is what I am suspecting is happening with yours. But first link back up to the ECU and switch the tab to map edit and lets see if it shows and map information and if the TPS LIGHT COMES ON. Maybe the light is only active on the map edit tab. Also this would be the tab you read the ecu map in. I have to be honest I am a tune boy user as I bought mine when there was no tune ecu for rockets so i am winging it a little. It would also be good if someone like @Steel or @Claviger both have the special tune boy map could plug into his and go to the diagnostic page where he just changed his TPS and see if his TPS LIGHT IS GREEN. And alsocheck the test page for the light.Or anyone else who has a special non tune ecu map. Heck even if they have a tune ecu ma in it they could report the results so we or at least I can learn
It could be that on the diagnostic page it does not enter the area of the map in the ecu maybe like it is a section of Global Variables or Permanent Comon Variables that are maintained where as local varribles could be used to pass information to arguments for say caculations for given condititions or conditioal staments or for passing information. Something to me If,Then, and while statments. Keep in mind I am not a programer with the exception of Parametric programing. Like Fanuc's Custom Macro A & B, Okuma's User task II, and Fadal's macro. I am guessing there us arguments and conditional statement in some for of tree theroy programming. Darn I never should have dropped out of school when I was a kid.
