Morph1976
.060 Over
- Joined
- Sep 8, 2020
- Messages
- 110
- Ride
- Rocket 3 tourer 07
My rocket was running rough and got it down to a faulty TPS sensor and one of the harnesses [every time I moved the harness the tps readings changed)
Looking online I’ve found the tps voltage tolerance should be between .60 - .64v and the stepper motor between .72 - .80v. Now the issue I have is that if it set both the primary and secondary tps to .61v the stepper gives a reading of .53v. If I set the TPs at .67v then the stepper then gives a reading of .72. I can’t seem to get the readings correct. Is there a way of setting the TPs correctly and then manually (or with a programme like tune ecu) setting the stepper motor to the correct voltage or am I missing something. Could it be a faulty sensor . It may be worth mentioning that I have the 3 kn filter setup and have removed the butterfly shims from the secondary
