My apologies I was picturing another bike. It only has 1.
Is it mechanically drifting i.e. you can see the bolt is in a different position relative to the slot in the sensor after a few hundred miles, or electronically drifting as in the volts as found when doing the ISCV reset are different than where you left it?
Presume this is a new TPS came in a little bag with a Triumph label with the part number on it, and you're using TuneECU to set it correctly.
That bolt looks different to any i've got with a TPS.
