The point I was trying to make was that personal experience is not the only valid basis for having an opinion.
When it comes to tires, I see no reason to use a car tire. I have found that tires designed for the bike perform as well as I need them to perform. So far I prefer the Avon Cobras, but haven't tried the Bridgestones yet. They will be next.
Many here feel a car tire will handle as well as a motorcycle tire. I find the handling with motorcycle tires limited by ground clearance, not tire grip. As for stopping power, I've found that overuse of the rear brake is the biggest cause of traction issues. If you can't resist stomping on the rear brake, then yes, perhaps a car tire is a better choice. But if you're not taking advantage of the weight transfer and using mainly the front brake, I believe your stopping distances will suffer.
Now, if cost is the issue then absolutely a car tire is cheaper and will last longer. Coming from sportier bikes with tires that lasted 4-5,000 miles at best, I find the 8-10,000 I get on the R3T to be a luxury. When thinking about cost I equate the decision with using a quality helmet. If I couldn't afford a good one, I'd get a cheaper bike.
So, there's my opinion. Based on zero experience with car tires. But, after 51 years on motorcycle tires, I'll likely stick with what's worked so far.
all over him!
